[Qgis-developer] Map vs. Line line labelling orientation
Sandro Santilli
strk at keybit.net
Sat Oct 22 12:08:17 EDT 2011
On Sat, Oct 22, 2011 at 01:01:26PM -0300, Martin Dobias wrote:
> On Sat, Oct 22, 2011 at 12:51 PM, Sandro Santilli <strk at keybit.net> wrote:
> > On Sat, Oct 22, 2011 at 12:45:33PM -0300, Martin Dobias wrote:
> >> the intended semantics is as follows:
> >> - with the "map" orientation the "above line" and others should work
> >> as one would expect: the label should appear above the line
> > What would you expect when the line is a vertical line ?
> I would expect that with "above line" placement a line going up gets
> the label on the left side. Contrary, a line going down should have
> the label on the right side.
Wouldn't this be against the concept of being line-orientation-agnostic ?
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
