[Qgis-developer] Expression based labeling
Martin Dobias
wonder.sk at gmail.com
Thu Oct 27 17:38:52 EDT 2011
On Thu, Oct 27, 2011 at 6:24 PM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> Ok pull request sent with a patch for the missing preview output and to
> enable multiline labels by default. Enabled multiline by default because
> users seem to struggle to get multiline working unless that feature is told
> to them.
The question is whether it ever makes sense to disable multiline
labels. Therefore for the simplicity of the GUI I would suggest to
remove the option completely and always keep it on... unless there is
a case when multiline labels should be explicitly disabled?
Martin
