[Qgis-developer] Expression based labeling
    Andreas Neumann
    a.neumann at carto.net
    Fri Oct 28 02:20:48 EDT 2011
> I agree. I can't really think of a use case where you wouldn't need
> it
> on always.  Looking at the code it seems that adding the direction
> symbol to the label doesn't work with multiline labels.
 the direction symbol is important for us. We use it to label the
 direction of waste-water pipes. We use them only in single-line labels
 though.
 I also can't think of cases where multiline labels need be set to off,
 other than potential issues in the code?
> Maybe just enable it by default for now, fix the direction symbol
> stuff, remove it....wait for someone to bring it up as a issue.
 sounds good.
 Andreas
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
