[Qgis-developer] Expression based labeling
Andreas Neumann
a.neumann at carto.net
Sun Oct 30 08:55:56 EDT 2011
Hi Nathan,
This would be ok for me. In reality, we are using this direction symbol
only with single lines anyway - and what you suggest sounds also good
for multiline labels.
Thanks again,
Andreas
On 10/29/2011 08:27 AM, Nathan Woodrow wrote:
>> the direction symbol is important for us. We use it to label the direction
>> of waste-water pipes. We use them only in single-line labels though.
> Would it be an OK solution to add the > to the last line and the < to the
> first line.
> eg
> Line 1
> Line 2 >
> or
> < Line 1
> Line 2
> At the moment this is the only thing really stopping us from removing the
> multiline option and just letting the code handle multilines as the default
> action.
> - Nathan
