[Qgis-developer] Re: generalizer
p0cisk
p0cisk at o2.pl
Sun Sep 4 12:57:08 EDT 2011
My chaiken algorithm differs from GRASS v.generalize. It's based on method
described here:
http://www.multires.caltech.edu/teaching/demos/java/chaikin.htm and uses
level and weight parameters to calculate output line while GRASS chaiken's
uses only threshold parameter.
If you play with demo on then site I linked above you will understand how my
algorithm works.
Regards
Peter
View this message in context: http://osgeo-org.1803224.n2.nabble.com/generalizer-tp6741351p6758717.html
Sent from the qgis-developer mailing list archive at Nabble.com.
