[Qgis-developer] Re: generalizer
Paolo Cavallini
cavallini at faunalia.it
Sun Sep 4 13:52:50 EDT 2011
Il 04/09/2011 18:57, p0cisk ha scritto:
> http://www.multires.caltech.edu/teaching/demos/java/chaikin.htm and uses
> level and weight parameters to calculate output line while GRASS chaiken's
> uses only threshold parameter.
> If you play with demo on then site I linked above you will understand how my
> algorithm works.
Yes, I have read it.
Perhaps you could add an About button, with links to the explanations of parameters
and algorithms?
All the best.
Paolo Cavallini: http://www.faunalia.it/pc
