[Qgis-developer] new plugin scenario
Richard Duivenvoorde
rdmailings at duif.net
Tue Sep 6 16:51:23 EDT 2011
On 2011-08-27 11:20, Martin Dobias wrote:
>> Did you upload your pubkey?
>> http://hub.qgis.org/my/public_keys
> No I didn't. Now after adding my public key and trying e.g.
> $ git clone gitosis at qgis.org:metaedit.git
> I get correctly asked for my passphrase for the private key. But then
> the cloning fails:
I do have a similar problem now I think.
I added a new plugin both to hub.qgis.org and to the git there
http://hub.qgis.org/projects/xytools/
Everything went fine: adding a new project, initing git, uploading a key
following the instruction in the 'Repository'-tab:
git init
git add .
git status
git commit -m 'Initializing xytools repository'
git remote add origin gitosis at qgis.org:xytools.git
git push origin master
And I now see my initial commit:
http://hub.qgis.org/projects/xytools/repository
But after that, I'm not able to push to the repository anymore...
Like Martin I get asked for a pass-phrase I do not know...
Maybe a hint: if I look in the http://hub.qgis.org/my/public_keys, I see
that it ends on richard at zwam (machine name) instead of richard at duif.net ...
Maybe this part of the ssh session is useful?
$ssh -v gitosis at qgis.org
OpenSSH_5.8p1 Debian-1ubuntu3, OpenSSL 0.9.8o 01 Jun 2010
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: Applying options for *
debug1: Connecting to qgis.org [140.211.15.67] port 22.
debug1: Connection established.
debug1: identity file /home/richard/.ssh/id_rsa type -1
debug1: identity file /home/richard/.ssh/id_rsa-cert type -1
debug1: identity file /home/richard/.ssh/id_dsa type -1
debug1: identity file /home/richard/.ssh/id_dsa-cert type -1
debug1: identity file /home/richard/.ssh/id_ecdsa type -1
debug1: identity file /home/richard/.ssh/id_ecdsa-cert type -1
debug1: Remote protocol version 2.0, remote software version
OpenSSH_5.1p1 Debian-5
debug1: match: OpenSSH_5.1p1 Debian-5 pat OpenSSH*
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_5.8p1 Debian-1ubuntu3
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: server->client aes128-ctr hmac-md5 none
debug1: kex: client->server aes128-ctr hmac-md5 none
debug1: SSH2_MSG_KEX_DH_GEX_REQUEST(1024<1024<8192) sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_GROUP
debug1: SSH2_MSG_KEX_DH_GEX_INIT sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_REPLY
debug1: Server host key: RSA a7:05:f6:a5:02:ec:92:73:4a:0a:12:16:4c:11:e1:1c
debug1: Host 'qgis.org' is known and matches the RSA host key.
debug1: Found key in /home/richard/.ssh/known_hosts:27
debug1: ssh_rsa_verify: signature correct
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: SSH2_MSG_NEWKEYS received
debug1: Roaming not allowed by server
debug1: SSH2_MSG_SERVICE_REQUEST sent
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue: publickey,password
debug1: Next authentication method: publickey
debug1: Trying private key: /home/richard/.ssh/id_rsa
debug1: Trying private key: /home/richard/.ssh/id_dsa
debug1: Trying private key: /home/richard/.ssh/id_ecdsa
debug1: Next authentication method: password
