[Qgis-developer] 1.7.1 Branch created
MORREALE Jean Roc
jr.morreale at enoreth.net
Mon Sep 12 17:17:06 EDT 2011
Le 11/09/2011 21:19, Tim Sutton a écrit :
> Hi
> On Sun, Sep 11, 2011 at 8:48 PM, MORREALE Jean Roc
> <jr.morreale at enoreth.net> wrote:
>> Le 08/09/2011 00:14, Tim Sutton a écrit :
>>> Hi Folks
>>> I have created a branch for 1.7.1.
>>> git branch --track release-1_7_1 origin/release-1_7_1
>>> Origin being the main git repo. It would be great if folks would
>>> test it compiles on their platform and generally behaves ok.
>>> I have a few more things to change before we tag it for the 1.7.1
>>> release.
>>> Please consider the old 1_7_0 branch permanently frozen and apply
>>> any backports to the 1.7.1 branch.
>>> After the release, I will immediately branch 1.7.2 so that it is a
>>> bit more obvious which branch should be on the receiving end of your
>>> backports.
>>> Best regards
>> Hi Tim,
>> Could you tell me how to correctly add this branch to my local repo ? I've
>> been trying checkout/fetch/pull release-1_7_1 from origin or upstream but it
>> always gets ugly when merging.
> Above should do it for you then after that:
> git checkout release-1_7_1
> git pull origin release-1_7_1
>> The changes I would like to make are already in master but as I didn't use
>> properly the BACKPORT tag they're not in this branch, one could be directly
>> merged from master (doc/TRANSLATORS).
> If you can identify the commit id of your original commit, you can
> simply use cherry-pick to apply it (while inside the release branch):
> git cherry-pick<hash>
> Then push it up to the release branch:
> git push origin release-1_7_1
> Hope that helps!
> Regards
> Tim
it worked, thanks :)
