[Qgis-developer] New Labeling:
Andreas Neumann
a.neumann at carto.net
Tue Sep 13 15:39:20 EDT 2011
Hi Andrew,
The logic is that one often wants label positions separate from the
actual geometry. The new label tool allows x/y positions not only for
point geometries (where one can use the point geometry), but also for
line and area features. If x/y columns are empty, QGIS uses the featurue
geometry, if one manually moves the labels, x/y columns are used. This
way one can mix manual and automatic labeling.
If you want fully automatic labeling just create dummy x/y columns and
never manually move labels around.
Does it sound illogical to you?
Andreas
On 09/13/2011 04:58 PM, Andrew Chapman wrote:
> I'm trying to find a way to use data defined positioning with the new
> labelling to replicate what is possible in the old labelling, namely
> aligning and rotating about the point specified for a layer.
> With the new labelling, fields have to be selected for label distance X & Y
> coordinates before the horizontal & vertical alignment plus rotation are
> enabled. Is there a logical reason why alignment and rotation aren't
> available by default?
> I tried creating a dummy field (always NULL values) and selecting it for
> distance, X & Y. This enables the other fields (to the extent that I can
> select them), but they seem to have no effect.
> Am I missing something or do I need to file a bug report?
> Andrew
> Qgis-developer mailing list
