[Qgis-developer] Feature: Auto saving for layers
Andreas Neumann
a.neumann at carto.net
Sun Sep 18 07:50:31 EDT 2011
I think it would be very useful to have autosave - however, the one
drawback one will have is that you loose the ability to undo changes.
This is not primarily an autosave issue but an issue with "save" in
general. As a use it is very annoying that the undo queue is emptied
through a save. And other software (like OpenOffice, Inkscape, Gimp)
works differently - it still offers undo
Are there any major difficult problems to solve to allow an undo/redo
queue across multiple saves?
Andreas
On 09/17/2011 07:10 AM, Nathan Woodrow wrote:
> Hi All,
> Last night I thought it might be cool to try and implement auto saving for
> layers that are in edit mode in QGIS. There was a request [1] opened up a
> while ago and while a plugin could have been made to fill the hole I think
> that this kind of stuff is nice to have built in.
> So I had a go at adding it myself. The idea is that you can set the auto
> save interval, in milliseconds (will change to seconds), for each layer.
> After that a timer fires at the interval and saves the layer for you. I
> thought a per-layer auto save feature is better then a blanket auto save for
> all as it gives the user more control.
> I added a checkable button in a dropdown style button (like measure tools)
> under the normal save button, that when selected asks the user for a
> interval and then enables autosaving.
> The branch for my changes are at
> https://github.com/NathanW2/Quantum-GIS/tree/autosave I would love if people
> would be able to test it for me and make sure I haven't made any mistakes
> while coding (still newish to Qt & C++).
> [1] http://hub.qgis.org/issues/4135
> Regards,
> Nathan Woodrow
> http://woostuff.wordpress.com/
> Qgis-developer mailing list
