[Qgis-developer] QGIS 1.7.0, crash with new labeling system
Ramon Andiñach
custard at westnet.com.au
Thu Sep 22 04:19:08 EDT 2011
Did QGIS crash while you were using the labels dialogue, when you closed it or a little while later?
I have the same setup as you describe, except 64-bit and don't seem to be having problems with your test file.
The filename looks weird. The projection is coming up as a custom CRS and is definitely weird. Labels fine.
-ramon.
On 22/09/2011, at 14:40, Golubev <golubev at nordcomp.ru> wrote:
> Hi devs!
> I have a vector layer with cyrillic name and when new labeling applied to this layer QGIS crashes. After renaming to english it works. Old labeling works fine with english or cyrillic names.
> Win 7 Pro (32 bit), QGIS 1.7.0 rev. 63ecdd7 from OSGeo4W, test layer included
> <test_shape.zip>
> Qgis-developer mailing list
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110922/6b96d6ce/attachment.html
