[Qgis-developer] QGIS 1.7.0, crash with new labeling system
Golubev
golubev at nordcomp.ru
Thu Sep 22 04:29:24 EDT 2011
QGIS crashes when i click Ok/Apply buttons in labels dialog
22.09.2011 12:19, Ramon Andiñach ?????:
> Did QGIS crash while you were using the labels dialogue, when you
> closed it or a little while later?
> I have the same setup as you describe, except 64-bit and don't seem to
> be having problems with your test file.
> The filename looks weird. The projection is coming up as a custom CRS
> and is definitely weird. Labels fine.
> -ramon.
> Qgis-developer mailing list
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110922/f48f9d5c/attachment-0001.html
