[Qgis-developer] QGIS 1.7.0, crash with new labeling system
Ramon Andiñach
custard at westnet.com.au
Thu Sep 22 06:03:04 EDT 2011
Then I'm afraid I'm out of my depth, and you'll have wait for one of the more experienced folk.
A passing thought; I've had problems with the new symbology + print manager when it took exception to one polygon in my shape file (for no apparent reason). This showed up in DebugView, and Andreas spotted it for me. If you ran DebugView while playing with the new labels, it might tell you what was wrong a little more precisely. (or you could add bits of the log here, and that would help someone tell you what was wrong).
-ramon.
On 22/09/2011, at 16:29 , Golubev wrote:
> QGIS crashes when i click Ok/Apply buttons in labels dialog
> 22.09.2011 12:19, Ramon Andiñach пишет:
>> Did QGIS crash while you were using the labels dialogue, when you closed it or a little while later?
>> I have the same setup as you describe, except 64-bit and don't seem to be having problems with your test file.
>> The filename looks weird. The projection is coming up as a custom CRS and is definitely weird. Labels fine.
>> -ramon.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
