[Qgis-developer] Problem configuring own repository/plugins
Andrew Chapman andrew.chapman at donkagen.co.uk
Thu Sep 22 16:48:31 EDT 2011
I'm trying to load my second test plugin to my own repository. The first
installs into QGIS without difficulty, but I'm missing something with the
second.
I get a message from the plugin installer that "Plugin has disappeared" -
actually it doesn't install in its own directory but puts its files and
sub-directory directly into python\plugins.
I've clearly got something wrong, but as far as I can see the plugins.xml
entries only differ by file name and the zip file structure looks the same.
What actually determines exactly where the files are written?
Andrew Chapman
