[Qgis-developer] error in 1-band plugin
Benoit
benoit-3 at bc-consult.com
Sat Sep 24 13:57:28 EDT 2011
Hi Giovanni,
On 24/09/11 14:27, Giovanni Manghi wrote:
> Hi Benoit,
>> A work around is to delete the file rastername.bccPAL1 located in the
>> same folder as the raster file.
> This workaround works.
I'm not sure if Paolo hit an other bug?
> A couple of questions: it would be very hard to apply directly the
> colormap after clicking on "create"? It is not very handy to have to go
> an pick the .txt file.
Yes, you can.... (a bit contrived perhaps!)
The selected colour palette name is added to the bottom drop-down
listbox after you click 'Create'. If you 'Create' more than one colour
table you end up with a list of colour palettes in that drop-down listbox.
Select one of them and then click 'Done'. Your raster should now be
'coloured' with that selected colour table, no need to load the .txt
file anymore...
P.S. The help page should explain the procedure....
> Why not saving the colormaps in .qml files?
Laziness & inexperience, surely! Still learning...
Cheers,
Benoit
> cheers
> -- Giovanni --
