[Qgis-developer] error in 1-band plugin
Benoit
benoit-3 at bc-consult.com
Sun Sep 25 12:57:46 EDT 2011
Hi Giovanni,
On 25/09/11 15:19, Giovanni Manghi wrote:
>> The selected colour palette name is added to the bottom drop-down
>> listbox after you click 'Create'. If you 'Create' more than one colour
>> table you end up with a list of colour palettes in that drop-down listbox.
>> Select one of them and then click 'Done'. Your raster should now be
>> 'coloured' with that selected colour table, no need to load the .txt
>> file anymore...
>> P.S. The help page should explain the procedure....
> Noticed another bug:
> when applying a colortable with QGIS now you see it in the TOC with
> values beside colors.
> With colortables created with your plugin in the TOC are visible only
> the colors but beside the values are not shown.
Yes, it was the behaviour before some changes have been made to the API.
I do have a version that add values (Labels) but is it not really
debugged for release as yet...
Cheers,
Benoit
> Cheers
> -- Giovanni --
