[Qgis-developer] error in 1-band plugin
Giovanni Manghi
giovanni.manghi at gmail.com
Sun Sep 25 09:19:27 EDT 2011
> The selected colour palette name is added to the bottom drop-down
> listbox after you click 'Create'. If you 'Create' more than one colour
> table you end up with a list of colour palettes in that drop-down listbox.
> Select one of them and then click 'Done'. Your raster should now be
> 'coloured' with that selected colour table, no need to load the .txt
> file anymore...
> P.S. The help page should explain the procedure....
Noticed another bug:
when applying a colortable with QGIS now you see it in the TOC with
values beside colors.
With colortables created with your plugin in the TOC are visible only
the colors but beside the values are not shown.
Cheers
-- Giovanni --
