[Qgis-developer] Re: [Qgis-user] More problems with 1.7.1
Agustin Lobo
alobolistas at gmail.com
Mon Sep 26 09:51:26 EDT 2011
Thanks for your help.
Just had reinstalled again (same repositories, using Synaptic) all
qgis related packages before lunch and it works fine now.
Cannot understand why, I have always upgraded using the Upgrade
Manager and never had this problem. Also,
no errors were reported after the first upgrade. Perhaps some of the
packages have actually been changed in the
ubuntugis-unstable repository between the two upgrades?
Anyway, I was kind of worried of not being able of going back to
1.7.0, as 1.7.0 was not on either ubuntugis stable or
unstable. Next time, could the previous version be kept somewhere
(stable, test, unstable)?
This is the output you were asking for, a pity I did not do it before
the second upgrade. Nevertheless, I did check with Synaptic
and the versions of all those marked here as ii were the same. Except
qgis-sqlanywhere1.7.1, that was not installed:
alobo at delia:~$ dpkg -l | grep qgis
rc libqgis1.4.0 1.4.0-2~lucid8
Quantum GIS - shared libraries
rc libqgis1.5.0 1.5.0-2~lucid2
rc libqgis1.6.0 1.6.0-4~lucid1
ii libqgis1.7.0 1.7.0~lucid1
ii libqgis1.7.1 1.7.1-1~lucid1
ii python-qgis 1.7.1-1~lucid1
Python bindings to Quantum GIS
ii python-qgis-common 1.7.1-1~lucid1
Python bindings to Quantum GIS -
architectur
ii qgis 1.7.1-1~lucid1
Geographic Information System (GIS)
ii qgis-api-doc 1.7.1-1~lucid1
Quantum GIS API documentation
ii qgis-common 1.7.1-1~lucid1
Quantum GIS - architecture-independent data
ii qgis-mapserver 1.7.1-1~lucid1
Quantum GIS mapserver
ii qgis-plugin-grass 1.7.1-1~lucid1
GRASS plugin for Quantum GIS
ii qgis-plugin-grass-common 1.7.1-1~lucid1
GRASS plugin for Quantum GIS -
architecture-
ii qgis-providers 1.7.1-1~lucid1
collection of data providers to Quantum GIS
ii qgis-providers-common 1.7.1-1~lucid1
rc qgis-sqlanywhere1.7.0 1.7.0~lucid1
Quantum GIS sql anywhere plugin and
provider
ii qgis-sqlanywhere1.7.1 1.7.1-1~lucid1
provider
alobo at delia:~$
2011/9/26 Tim Sutton <lists at linfiniti.com>:
> Hi
> On Mon, Sep 26, 2011 at 10:06 AM, Agustin Lobo <alobolistas at gmail.com> wrote:
>> Not obvious at all: according to Synaptic the same upgrade installed
>> python-qgis 1.7.1.~lucid1
>> python-qgis-common 1.7.1.~lucid1
>> etc
>> all qgis entries are 1.7.1.~lucid1 and from the same repository
> Can you do a
> dpkg -l | grep qgis and post the result?
> Thanks
> Tim
>> Agus
> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
