[Qgis-developer] Re: [Qgis-user] More problems with 1.7.1
Tim Sutton
lists at linfiniti.com
Mon Sep 26 13:52:13 EDT 2011
HI
On Mon, Sep 26, 2011 at 3:51 PM, Agustin Lobo <alobolistas at gmail.com> wrote:
> Thanks for your help.
> Just had reinstalled again (same repositories, using Synaptic) all
> qgis related packages before lunch and it works fine now.
> Cannot understand why, I have always upgraded using the Upgrade
> Manager and never had this problem. Also,
> no errors were reported after the first upgrade. Perhaps some of the
> packages have actually been changed in the
> ubuntugis-unstable repository between the two upgrades?
> Anyway, I was kind of worried of not being able of going back to
> 1.7.0, as 1.7.0 was not on either ubuntugis stable or
> unstable. Next time, could the previous version be kept somewhere
> (stable, test, unstable)?
> This is the output you were asking for, a pity I did not do it before
> the second upgrade. Nevertheless, I did check with Synaptic
> and the versions of all those marked here as ii were the same. Except
> qgis-sqlanywhere1.7.1, that was not installed:
> alobo at delia:~$ dpkg -l | grep qgis
> rc libqgis1.4.0 1.4.0-2~lucid8
> Quantum GIS - shared libraries
> rc libqgis1.5.0 1.5.0-2~lucid2
> rc libqgis1.6.0 1.6.0-4~lucid1
> ii libqgis1.7.0 1.7.0~lucid1
So probably you want to remove libqgis1.7.0
Regards
Tim
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
