[Qgis-developer] Polishing QGIS
Barry Rowlingson
b.rowlingson at lancaster.ac.uk
Mon Sep 26 10:16:25 EDT 2011
On Mon, Sep 26, 2011 at 12:58 PM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> FYI a good site for doing UI mockup
> is http://builds.balsamiq.com/b/mockups-web-demo/
I've looked at these sorts of wireframe mockup builders a bit - but
for Qgis, a Qt application, isn't it just easier to drag n drop stuff
around using QtDesigner? Then you not only know you are using widgets
from the right toolkit, but you can also directly test your interface,
you can write little python test harnesses, and you dont end up having
to redo your design in a different system once you've finalised it.
Barry
