[Qgis-developer] questions on rendering
Mohammed Rashad
mohammedrashadkm at gmail.com
Tue Sep 27 10:51:01 EDT 2011
On Tue, Sep 27, 2011 at 8:10 PM, Martin Dobias <wonder.sk at gmail.com> wrote:
> On Tue, Sep 27, 2011 at 4:18 PM, Mohammed Rashad
> <mohammedrashadkm at gmail.com> wrote:
> > Hi All,
> > I am developing tiled vector rendering in OSSIM. I like the Qgis vector
> > rendering system
> > point.shp contains 9,99,999 points which are generated by grass for using
> > v.random and ~27MB in size
> > roads.shp contains 2,28,068 linestrings and is ~50MB in size
> > these point.shp and roads.shp data gets rendered in ~10 sec
> > When I read vector using ogr and parse feature and draw point/linestring
> my
> > application taking about 40 sec to render point.shp
> > and
> > I am using Qt4 with QPainter not QGraphicsView
> > How came this time gap?
> Most likely you have some inefficiencies in your implementation.
Can you tell where i have inefficiencies I do direct rendering Qt Painter
and OGR?
> > i see Rtree and pal libs in src/core source code
> > Does they have any role in rendering?
> No - unless you also draw labels.
> > Does QGIS Rendering uses threading?
> No - only in threading branch which has not yet been integrated.
> > How to get a minimal of QGIS code to hack it and build a new vector
> > rendering because I need it to make it tiled rendering vectors?
> You can use qgis_core library to do tiled drawing.
> > How to improve performance in rendering without qgis?
> Learn how to profile programs - i.e. get time spent in individual
> functions, analyze the results and fix the places where most of the
> time is spent.
How to do profiling? how is works? please tell me some samples for
profiling..
> Martin
Regards,
Mohammed Rashad K M
M.S. (By Research) student
Lab for Spatial Informatics
Department of CSE
International Institute of Information Technology
Hyderabad, India
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110927/a48abc17/attachment.html
