[Qgis-developer] questions on rendering
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Tue Sep 27 10:55:18 EDT 2011
Hi Mohammed
> How came this time gap?
A possible reason could be the following:
In QGIS, most point renderers do some caching of the point symbols as QImage.
So in case you invoke a QPainter->drawCircle/drawRectangle etc. command for
every point, it helps a lot do do the rasterisation only once.
Regards,
Marco
Am Dienstag, 27. September 2011, 16.18:25 schrieb Mohammed Rashad:
> Hi All,
> I am developing tiled vector rendering in OSSIM. I like the Qgis vector
> rendering system
> point.shp contains 9,99,999 points which are generated by grass for using
> v.random and ~27MB in size
> roads.shp contains 2,28,068 linestrings and is ~50MB in size
> these point.shp and roads.shp data gets rendered in ~10 sec
> When I read vector using ogr and parse feature and draw point/linestring my
> application taking about 40 sec to render point.shp
> and
> I am using Qt4 with QPainter not QGraphicsView
> i see Rtree and pal libs in src/core source code
> Does they have any role in rendering?
> Does QGIS Rendering uses threading?
> How to get a minimal of QGIS code to hack it and build a new vector
> rendering because I need it to make it tiled rendering vectors?
> How to improve performance in rendering without qgis?
> Regards,
> Mohammed Rashad K M
> M.S. (By Research) student
> Lab for Spatial Informatics
> Department of CSE
> International Institute of Information Technology
> Hyderabad, India
