[Qgis-developer] questions on rendering
Mohammed Rashad
mohammedrashadkm at gmail.com
Tue Sep 27 12:04:41 EDT 2011
On Tue, Sep 27, 2011 at 8:25 PM, Marco Hugentobler <
marco.hugentobler at sourcepole.ch> wrote:
> Hi Mohammed
> > How came this time gap?
> A possible reason could be the following:
> In QGIS, most point renderers do some caching of the point symbols as
> QImage.
> So in case you invoke a QPainter->drawCircle/drawRectangle etc. command for
> every point, it helps a lot do do the rasterisation only once.
the point is not clear for me maybe because of my misunderstanding
will you please eloborate??
> Regards,
> Marco
> Am Dienstag, 27. September 2011, 16.18:25 schrieb Mohammed Rashad:
> > Hi All,
> > I am developing tiled vector rendering in OSSIM. I like the Qgis vector
> > rendering system
> > point.shp contains 9,99,999 points which are generated by grass for using
> > v.random and ~27MB in size
> > roads.shp contains 2,28,068 linestrings and is ~50MB in size
> > these point.shp and roads.shp data gets rendered in ~10 sec
> > When I read vector using ogr and parse feature and draw point/linestring
> my
> > application taking about 40 sec to render point.shp
> > and
> > I am using Qt4 with QPainter not QGraphicsView
> > i see Rtree and pal libs in src/core source code
> > Does they have any role in rendering?
> > Does QGIS Rendering uses threading?
> > How to get a minimal of QGIS code to hack it and build a new vector
> > rendering because I need it to make it tiled rendering vectors?
> > How to improve performance in rendering without qgis?
> > Regards,
> > Mohammed Rashad K M
> > M.S. (By Research) student
> > Lab for Spatial Informatics
> > Department of CSE
> > International Institute of Information Technology
> > Hyderabad, India
Regards,
Mohammed Rashad K M
Department of CSE
Hyderabad, India
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110927/7ab14628/attachment-0001.html
