[Qgis-developer] questions on rendering
Mohammed Rashad
mohammedrashadkm at gmail.com
Wed Sep 28 08:08:59 EDT 2011
does QGIS paint points to QPixMap and render the image or QGIS directly
draws the point
like painter->drawCircle/point
On Tue, Sep 27, 2011 at 9:34 PM, Mohammed Rashad <mohammedrashadkm at gmail.com
> wrote:
> On Tue, Sep 27, 2011 at 8:25 PM, Marco Hugentobler <
> marco.hugentobler at sourcepole.ch> wrote:
>> Hi Mohammed
>> > How came this time gap?
>> A possible reason could be the following:
>> In QGIS, most point renderers do some caching of the point symbols as
>> QImage.
>> So in case you invoke a QPainter->drawCircle/drawRectangle etc. command
>> for
>> every point, it helps a lot do do the rasterisation only once.
> the point is not clear for me maybe because of my misunderstanding
> will you please eloborate??
>> Regards,
>> Marco
>> Am Dienstag, 27. September 2011, 16.18:25 schrieb Mohammed Rashad:
>> > Hi All,
>> > I am developing tiled vector rendering in OSSIM. I like the Qgis vector
>> > rendering system
>> > point.shp contains 9,99,999 points which are generated by grass for
>> using
>> > v.random and ~27MB in size
>> > roads.shp contains 2,28,068 linestrings and is ~50MB in size
>> > these point.shp and roads.shp data gets rendered in ~10 sec
>> > When I read vector using ogr and parse feature and draw point/linestring
>> my
>> > application taking about 40 sec to render point.shp
>> > and
>> > I am using Qt4 with QPainter not QGraphicsView
>> > i see Rtree and pal libs in src/core source code
>> > Does they have any role in rendering?
>> > Does QGIS Rendering uses threading?
>> > How to get a minimal of QGIS code to hack it and build a new vector
>> > rendering because I need it to make it tiled rendering vectors?
>> > How to improve performance in rendering without qgis?
>> > Regards,
>> > Mohammed Rashad K M
>> > M.S. (By Research) student
>> > Lab for Spatial Informatics
>> > Department of CSE
>> > International Institute of Information Technology
>> > Hyderabad, India
> Regards,
> Mohammed Rashad K M
> Department of CSE
> Hyderabad, India
Regards,
Mohammed Rashad K M
Department of CSE
Hyderabad, India
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110928/56426b68/attachment.html
