[Qgis-developer] Re: Working on Symbology Improvement for the GSOC
kimaidou
kimaidou at gmail.com
Sun Apr 1 08:53:04 EDT 2012
Nathan, if I understand correctly, your mockup is for labelling, but you
say we could use exactly the same kind for symbology ?. If so, I proposed
in my previous post the "Data defined settings" tab for symbology, which
will list all the properties wich can be configured this way.
The icon idea is a good one too, and could make the "Data defined settings"
useless if all the settings can use it.It will require more efforts as you
will have to change the ui so that each control can be turned off and on
again depending of the database icon state, but this will be a great
enhancement. No more 2 different dialogs to set the same property
Michael
2012/4/1 Nathan Woodrow <madmanwoo at gmail.com>
> Good idea I have a mockup UI [attached] for doing this kind of thing.
> Idea is: Click on the little database icon a it switches the normal
> control onto a combo box so that you can pick from a field.
> - Nathan
> On Sun, Apr 1, 2012 at 10:23 PM, kimaidou <kimaidou at gmail.com> wrote:
>> Hi list,
>> Another thing that would be great for symbology would be the ability to
>> define symbology properties taken from layer columns, so that for the same
>> layer, feature "A" can have svgA.svg, feature "B" have "svgB.svg", or
>> decide which columns set the svg size, color, transparency, rotation, etc.
>> For now, in 1.8, we can only set rotation and size with the "advanced" list.
>> This would be a great feature which will help a lot to add some dynamic
>> symbology.
>> Michael
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120401/bd80ae60/attachment.html
