[Qgis-developer] Re: PyQGIS Auto-completion and Call Tips in Eric
Python Editor
Tim Sutton
lists at linfiniti.com
Mon Apr 9 15:00:00 EDT 2012
Hi Larry
On Mon, Apr 9, 2012 at 5:20 AM, Larry Shaffer <larrys at dakotacarto.com> wrote:
> On Sun, Apr 8, 2012 at 7:48 PM, Larry Shaffer <larrys at dakotacarto.com>
> wrote:
>> Hi,
>> I've successfully generated QScintilla2 API files for the QGIS Python
>> bindings and utility modules [0]. If you use the Eric4/5 Python editor (or
>> another based on QScintilla2), you may be interested in installing and
>> compiling these APIs.
> Seems a better approach, instead of changing SIPMacros.cmake, would be in
> python/CMakeLists.txt [0]:
> --- python/CMakeLists_orig.txt 2012-02-19 13:41:41.000000000 -0700
> +++ python/CMakeLists.txt 2012-04-08 21:00:16.000000000 -0600
> @@ -54,0 +55 @@
> +set(SIP_EXTRA_OPTIONS ${PYQT4_SIP_FLAGS} -o -a
> ${CMAKE_BINARY_DIR}/python/qgis.core.api)
> @@ -68,0 +70 @@
> ${CMAKE_BINARY_DIR}/python/qgis.gui.api)
> @@ -79,0 +82 @@
> ${CMAKE_BINARY_DIR}/python/qgis.analysis.api)
> This worked fine on compile, creating the same output as the SIPMacros.cmake
> edit. Each SIP_EXTRA_OPTIONS could be wrapped with a conditional based on a
> compile option for generating the APIs.
Two quick comments:
1) Could you submit your patch via github? If it is a cmake
conditional compilation I see no reason to exclude it from master -
others may have a different opinion.
2) What I would really *love* is to have QGIS api completion (and
other standard python modules if it is easy to achieve) in the built
in python console that is activeated from the QGIS plugins menu. I
often like to demo stuff to people using the python console and always
flap around trying to remember syntax. Obviously this would add a
qsctintilla dependency to QGIS core - how do others feel about this?
Given the other work you are busy with that dependency is probably
coming anyway....
Regards
Tim
> Regards,
> Larry Shaffer
> Dakota Cartography
> Black Hills, South Dakota
> [0] http://dl.dropbox.com/u/4058089/qgis/CMakeLists.txt
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
