[Qgis-developer] Re: PyQGIS Auto-completion and Call Tips in Eric
Python Editor
G. Allegri
giohappy at gmail.com
Mon Apr 9 16:06:02 EDT 2012
I would seriously consider upgrading the Python console, first of all to
support autocompletion. I suggested the incorporation of QScintilla a
couple of years ago, but it didn't raise much interest. A few weeks ago I
gave a look to iPython, and it's Qt console [1].
giovanni
[1] http://ipython.org/ipython-doc/dev/interactive/qtconsole.html
2012/4/9 Tim Sutton <lists at linfiniti.com>
> Hi Larry
> On Mon, Apr 9, 2012 at 5:20 AM, Larry Shaffer <larrys at dakotacarto.com>
> wrote:
> > On Sun, Apr 8, 2012 at 7:48 PM, Larry Shaffer <larrys at dakotacarto.com>
> > wrote:
> >> Hi,
> >> I've successfully generated QScintilla2 API files for the QGIS Python
> >> bindings and utility modules [0]. If you use the Eric4/5 Python editor
> (or
> >> another based on QScintilla2), you may be interested in installing and
> >> compiling these APIs.
> > Seems a better approach, instead of changing SIPMacros.cmake, would be in
> > python/CMakeLists.txt [0]:
> > --- python/CMakeLists_orig.txt 2012-02-19 13:41:41.000000000 -0700
> > +++ python/CMakeLists.txt 2012-04-08 21:00:16.000000000 -0600
> > @@ -54,0 +55 @@
> > +set(SIP_EXTRA_OPTIONS ${PYQT4_SIP_FLAGS} -o -a
> > ${CMAKE_BINARY_DIR}/python/qgis.core.api)
> > @@ -68,0 +70 @@
> > ${CMAKE_BINARY_DIR}/python/qgis.gui.api)
> > @@ -79,0 +82 @@
> > ${CMAKE_BINARY_DIR}/python/qgis.analysis.api)
> > This worked fine on compile, creating the same output as the
> SIPMacros.cmake
> > edit. Each SIP_EXTRA_OPTIONS could be wrapped with a conditional based
> on a
> > compile option for generating the APIs.
> Two quick comments:
> 1) Could you submit your patch via github? If it is a cmake
> conditional compilation I see no reason to exclude it from master -
> others may have a different opinion.
> 2) What I would really *love* is to have QGIS api completion (and
> other standard python modules if it is easy to achieve) in the built
> in python console that is activeated from the QGIS plugins menu. I
> often like to demo stuff to people using the python console and always
> flap around trying to remember syntax. Obviously this would add a
> qsctintilla dependency to QGIS core - how do others feel about this?
> Given the other work you are busy with that dependency is probably
> coming anyway....
> Regards
> Tim
> > Regards,
> > Larry Shaffer
> > Dakota Cartography
> > Black Hills, South Dakota
> > [0] http://dl.dropbox.com/u/4058089/qgis/CMakeLists.txt
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
> * QGIS programming and support services
> * Mapserver and PostGIS based hosting plans
> * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120409/f0472f69/attachment.html
