[Qgis-developer] SEXTANTE for QGIS has been released
Pedro Venâncio
pedrongvenancio at yahoo.com
Thu Apr 12 17:42:58 EDT 2012
Hi Salvatore,
Thank you very much, it works now on terminal!
However, still can not run any SAGA tool from the SEXTANTE plugin...
For instance, "Polygon centroids". SEXTANTE logs:
SAGA execution commands
libshapes_polygons "Polygon Centroids" -POLYGONS "/home/pedro/Limpezas/caop_2011_pinhel.shp" -CENTROIDS "/home/pedro/sextante/outputs_centroids.shp"
SAGA execution console output
18:47:44: Error: /home/pedro/libshapes_polygons.so: cannot open shared object file: No such file or directory
_____________________________________________
SAGA CMD 2.0.4
Load table: /home/pedro/saga.srs...
failed
error: Library could not be loaded [libshapes_polygons]
error: no valid module library found in path [/home/pedro]
type -h or --help for further information
In the terminal it works with exactly the same syntax as SEXTANTE:
pedro at debian-amilo:~$ saga_cmd libshapes_polygons "Polygon Centroids" -POLYGONS "/home/pedro/Limpezas/caop_2011_pinhel.shp" -CENTROIDS "/home/pedro/sextante/outputs_centroids.shp"
I still found something strange in some algorithms.
For example, the tool "Create Graticule" gives SEXTANTE error. Logs:
libshapes_tools "Create Graticule" -EXTENT "/home/pedro/Limpezas/caop_2011_pinhel.shp" -X_EXTENT_MIN 0 -X_EXTENT_MAX 0 -Y_EXTENT_MIN 0 -Y_EXTENT_MAX 0 -DISTX 100 -DISTY 100 -TYPE 0 -GRATICULE "/home/pedro/sextante/grid.shp"
21:06:57: Error: /home/pedro/libshapes_tools.so: cannot open shared object file: No such file or directory
SAGA CMD 2.0.4
failed
error: Library could not be loaded [libshapes_tools]
By running the command directly in the terminal, it gives an error by the fact that the module is "Create graticule" and not "Create Graticule" (case sensitive).
Then, there are some parameters in the syntax that does not match the accepted SAGA_CMD sintax. And the module only works like this:
$ saga_cmd libshapes_tools "Create graticule" -LINES "/home/pedro/sextante/grid.shp" -LIMIT_SHAPES "/home/pedro/Limpezas/caop_2011_pinhel.shp" -X_EXTENT_MIN 0 -X_EXTENT_MAX 0 -Y_EXTENT_MIN 0 -Y_EXTENT_MAX 0 -DISTX 1000 -DISTY 1000 -TYPE 0
The same applies, eg with the tool "Shapes Buffer". logs:
libshapes_tools "Shapes Buffer" -SHAPES "/home/pedro/sextante/outputs.shp" -BUF_TYPE 0 -BUF_DIST 100 -BUF_FIELD "AREA_T_HA" -BUF_SCALE 1 -BUF_ZONES 1 -DCIRCLE 5 -DISSOLVE -BUFFER "/home/pedro/sextante/outputs_buff.shp"
20:59:52: Error: /home/pedro/libshapes_tools.so: cannot open shared object file: No such file or directory
SAGA CMD 2.0.4
failed
In the terminal:
pedro at debian-amilo:~$ saga_cmd libshapes_tools "Shapes Buffer" -SHAPES "/home/pedro/sextante/outputs.shp" -BUF_TYPE 0 -BUF_DIST 100 -BUF_SCALE 1 -BUF_ZONES 1 -DCIRCLE 5 -DISSOLVE -BUFFER "/home/pedro/sextante/outputs_buff.shp"
SAGA CMD 2.0.4
failed
library path: /usr/lib/saga
library name: libshapes_tools
module name : Shapes Buffer
author : (c) 2008 by O.Conrad
go...
Unknown option 'DISSOLVE'
Usage: Shapes Buffer -SHAPES <str> -BUFFER <str> [-BUF_TYPE <num>] [-BUF_DIST <str>] [-BUF_FIELD <num>] [-BUF_SCALE <str>] [-BUF_ZONES <num>] [-DCIRCLE <str>]
-SHAPES:<str> Shapes
Shapes (input)
-BUFFER:<str> Buffer
Shapes (output)
-BUF_TYPE:<num> Buffer Distance
Choice
Available Choices:
[0] fix value
[1] attribute field
-BUF_DIST:<str> Buffer Distance (Fixed)
Floating point
Minimum: 0.000000
-BUF_FIELD:<num> Buffer Distance (Attribute)
Table field
-BUF_SCALE:<str> Scaling Factor for Attribute Value
Floating point
Minimum: 0.000000
-BUF_ZONES:<num> Number of Buffer Zones
Integer
Minimum: 1.000000
-DCIRCLE:<str> Circle Point Distance [Degree]
Floating point
Value Range: 0.010000 - 45.000000
error: executing module [Shapes Buffer]
This is how it works:
pedro at debian-amilo:~$ saga_cmd libshapes_tools "Shapes Buffer" -SHAPES "/home/pedro/sextante/outputs.shp" -BUF_TYPE 0 -BUF_DIST 100 -BUF_SCALE 1 -BUF_ZONES 1 -DCIRCLE 5 -BUFFER "/home/pedro/sextante/outputs_buff.shp"
Someone confirm this behavior?
Environment:
Debian 6.0.4 (squeeze)
QGIS 1.7.4 (SEXTANTE 1.0.2)
SAGA 2.0.4
Best regards,
Pedro Venâncio
----- Original Message -----
add access to SAGA libraries, if you have not done:
$ export SAGA_MLB=/usr/lib/saga
Also, try it using plugin SEXTANTE in QGIS!
For example: running the command "Convert Polygons to Lines"!
-SL
