[Qgis-developer] SEXTANTE for QGIS has been released
Salvatore Larosa
lrssvtml at gmail.com
Fri Apr 13 09:11:31 EDT 2012
Il giorno gio, 12/04/2012 alle 14.42 -0700, Pedro Venâncio ha scritto:
> For instance, "Polygon centroids". SEXTANTE logs:
> SAGA execution commands
> libshapes_polygons "Polygon Centroids" -POLYGONS "/home/pedro/Limpezas/caop_2011_pinhel.shp" -CENTROIDS "/home/pedro/sextante/outputs_centroids.shp"
> SAGA execution console output
> 18:47:44: Error: /home/pedro/libshapes_polygons.so: cannot open shared object file: No such file or directory
Is the *.so file found in /home/pedro? it sounds weird!
The libraries should be in /usr/lib/saga (SAGA_MLB) as you know already.
> In the terminal it works with exactly the same syntax as SEXTANTE:
pheraps because you run command "export SAGA_MLB" before!
I have a doubt, how did you to install SAGA lib? build, binary....?
Also try to install (build) the latest version 2.0.8!
-SL
