[Qgis-developer] Gdal version upgrade problems
Fri Apr 13 11:58:10 EDT 2012
On 12-04-13 08:41 AM, Rudi Thiede wrote:
> Hi all,
> It seems that upgrading GDAL has caused it to stop working... when starting
> QGIS, I get this:
> Couldn't load plugin GdalTools due an error when calling its classFactory() method
> Traceback (most recent call last):
>    File "/home/rudi/apps/qgis-1_8/share/qgis/python/qgis/utils.py", line 164,
> in startPlugin
>      plugins[packageName] = package.classFactory(iface)
>    File
> "/home/rudi/apps/qgis-1_8/share/qgis/python/plugins/GdalTools/__init__.py",
> line 32, in classFactory
>      from GdalTools import GdalTools
>    File "/home/rudi/apps/qgis-1_8/share/qgis/python/qgis/utils.py", line 309,
> in _import
>      mod = _builtin_import(name, globals, locals, fromlist, level)
>    File
> "/home/rudi/apps/qgis-1_8/share/qgis/python/plugins/GdalTools/GdalTools.py",
> line 39, in
>      raise ImportError( error_str )
> ImportError: /usr/lib/python2.7/dist-packages/osgeo/_gdal.so: symbol
> VSIFTruncateL, version GDAL_1.8 not defined in file libgdal.so.1 with link time
> reference
Rudi,
For what it's worth the problem seems to be that while your libgdal.so was
upgraded, the Python bindings were not.  So the _gdal.so from the python
bindings is still looking for 1.8.
I'm not sure how you upgraded GDAL, but if you built it yourself just make
sure you also are building and installing the python bindings.  You might want
to get rid of the old ones (/usr/lib/python2.7/dist-packages/osgeo) first.
Best regards,
light and sound - activate the windows | http://home.gdal.org/warmerda
and watch the world go round - Rush    | Geospatial Software Developer
