[Qgis-developer] Sextante: saga does not run
Victor Olaya
volayaf at gmail.com
Mon Apr 16 04:32:55 EDT 2012
Paolo
That is just something that I added to automatically test if SAGA is
installed, so it does not let you execute a SAGA algorithm if SAGA is
not installed. Clearly, it is not working, since it is obvious that
you have SAGA installed...
Let me work on it a bit more, because I am not sure that it is a good
idea... I am just thinking about how to make the configuration of
external applications easier, while being robust at the same time
Regarding the SAGA error, that is not a problem, do not worry about
that, you are just missing a library on the command line, because taht
library just contain interactive modules that cannot be run on the
console. It is a SAGa issue, but it should not bother you
regards
El día 16 de abril de 2012 10:25, Paolo Cavallini
<cavallini at faunalia.it> escribió:
> StartFragmentHi all.
> Just upgraded from svn, to test your fixes, now I get:
> It seems that SAGA is not correctly installed in your system.
> Please install it before running SAGA algorithms.
> No options are available to add the path to saga, so I'm stuck.
> In fact, starting saga_cmd returns a couple of errors:
> error: module library
> error: Library does not contain executable modules [librecreations_games.so]
> 59 SAGA Module Libraries
> Should I wait for the next release of the plugin before keeping on testing,
> or can I go on with trunk?
> All the best, and thanks.
> Paolo Cavallini
> See: http://www.faunalia.it/pc
> Qgis-developer mailing list
