[Qgis-developer] Sextante: saga does not run
Victor Olaya volayaf at gmail.com
Mon Apr 16 10:53:52 EDT 2012
Ok, then I will work on that a bit more to see what is going on :-)
Will keep you posted
Regards
El día 16 de abril de 2012 16:10, Paolo Cavallini
<cavallini at faunalia.it> escribió:
> Il 16/04/2012 16:03, Victor Olaya ha scritto:
> Paolo
> I fixed that. The checking I do is to try to execute saga_cmd without
> parameters and see if the response is the saga help screen or the
> console complaining about not finding that command. but I was not
> correctly checking the output of the saga_cmd (mispelled "-----"
> instead of "___")
> It is still a simple mechanism, but should work for now, and that at
> least guarantees that SAGA is installed before letting the user run
> anything. I created a similar thing for the R bindings
> Regards
> Victor
> El día 16 de abril de 2012 10:32, Victor Olaya <volayaf at gmail.com> escribió:
> Paolo
> That is just something that I added to automatically test if SAGA is
> installed, so it does not let you execute a SAGA algorithm if SAGA is
> not installed. Clearly, it is not working, since it is obvious that
> you have SAGA installed...
> Let me work on it a bit more, because I am not sure that it is a good
> idea... I am just thinking about how to make the configuration of
> external applications easier, while being robust at the same time
> Regarding the SAGA error, that is not a problem, do not worry about
> that, you are just missing a library on the command line, because taht
> library just contain interactive modules that cannot be run on the
> console. It is a SAGa issue, but it should not bother you
> regards
> El día 16 de abril de 2012 10:25, Paolo Cavallini
> StartFragmentHi all.
> Just upgraded from svn, to test your fixes, now I get:
> It seems that SAGA is not correctly installed in your system.
> Please install it before running SAGA algorithms.
> No options are available to add the path to saga, so I'm stuck.
> In fact, starting saga_cmd returns a couple of errors:
> error: module library
> error: Library does not contain executable modules [librecreations_games.so]
> 59 SAGA Module Libraries
> Should I wait for the next release of the plugin before keeping on testing,
> or can I go on with trunk?
> All the best, and thanks.
> Paolo Cavallini
> See: http://www.faunalia.it/pc
> Qgis-developer mailing list
> Hi Victor,
> gracias for this. Unfortunately I still get:
> after upgrading to r101
> All the best.
> Paolo Cavallini
