[Qgis-developer] Sextante: saga does not run
Paolo Cavallini
cavallini at faunalia.it
Mon Apr 16 10:10:18 EDT 2012
Il 16/04/2012 16:03, Victor Olaya ha scritto:
> Paolo
> I fixed that. The checking I do is to try to execute saga_cmd without
> parameters and see if the response is the saga help screen or the
> console complaining about not finding that command. but I was not
> correctly checking the output of the saga_cmd (mispelled "-----"
> instead of "___")
> It is still a simple mechanism, but should work for now, and that at
> least guarantees that SAGA is installed before letting the user run
> anything. I created a similar thing for the R bindings
> Regards
> Victor
> El día 16 de abril de 2012 10:32, Victor Olaya <volayaf at gmail.com> escribió:
>> Paolo
>> That is just something that I added to automatically test if SAGA is
>> installed, so it does not let you execute a SAGA algorithm if SAGA is
>> not installed. Clearly, it is not working, since it is obvious that
>> you have SAGA installed...
>> Let me work on it a bit more, because I am not sure that it is a good
>> idea... I am just thinking about how to make the configuration of
>> external applications easier, while being robust at the same time
>> Regarding the SAGA error, that is not a problem, do not worry about
>> that, you are just missing a library on the command line, because taht
>> library just contain interactive modules that cannot be run on the
>> console. It is a SAGa issue, but it should not bother you
>> regards
>> El día 16 de abril de 2012 10:25, Paolo Cavallini
>> <cavallini at faunalia.it> escribió:
>>> StartFragmentHi all.
>>> Just upgraded from svn, to test your fixes, now I get:
>>> It seems that SAGA is not correctly installed in your system.
>>> Please install it before running SAGA algorithms.
>>> No options are available to add the path to saga, so I'm stuck.
>>> In fact, starting saga_cmd returns a couple of errors:
>>> error: module library
>>> error: Library does not contain executable modules [librecreations_games.so]
>>> 59 SAGA Module Libraries
>>> Should I wait for the next release of the plugin before keeping on testing,
>>> or can I go on with trunk?
>>> All the best, and thanks.
>>> Paolo Cavallini
>>> See: http://www.faunalia.it/pc
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Hi Victor,
gracias for this. Unfortunately I still get:
after upgrading to r101
All the best.
Paolo Cavallini
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120416/44fb0786/attachment.html
