[Qgis-developer] Syntax for using QList<QgsMapLayer *> signal in
python
Larry Shaffer
larrys at dakotacarto.com
Thu Apr 19 12:32:28 EDT 2012
Hi Tim,
On Thu, Apr 19, 2012 at 3:33 AM, Tim Sutton <lists at linfiniti.com> wrote:
> Hi
> On Thu, Apr 19, 2012 at 11:28 AM, Tim Sutton <lists at linfiniti.com> wrote:
> > Hi
> > On Thu, Apr 19, 2012 at 11:14 AM, Denis Rouzaud <denis.rouzaud at gmail.com>
> wrote:
> >> I would try
> >> SIGNAL("layersWillBeRemoved(QStringList)")
> > Oh but its not a string list that the signal is emitting but rather a
> > QList of pointers to map layers?
> Oh sorry I see I was the source of confusion with my python snippet -
> yes it is the added slot I am interested in.
Well, I'm no PyQt wizard, but did you try:
Decorating your slot?
@pyqtSlot(list)
def getLayers(self, layers):
do stuff
Or maybe define it in the connection? (i.e. add [list]):
QgsMapLayerRegistry.instance().layersWillBeRemoved[list].connect(self.
getLayers)
Seems QList should be auto-converted to Python list type anyhow by PyQt.
Does the QgsMapLayerRegistry.instance() need assigned to a variable before
making a connection?
Another silly question: does getLayers() have enough parameters?
> >> On 04/19/2012 11:09 AM, Tim Sutton wrote:
> >> Hi All
> >> Does anyone know the appropriate way to connect to the new
> >> QgsMapLayerRegistry signal I added in python:
> >> void layersAdded( QList<QgsMapLayer *> theMapLayers );
> >> I tried:
> >> QtCore.QObject.connect(QgsMapLayerRegistry.instance(),
> >> QtCore.SIGNAL('layersWillBeRemoved(QList<QgsMapLayer*>)'),
> >> self.getLayers)
> >> But that doesnt seem to be hitting my slot.
Regards,
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120419/ac7fb337/attachment.html
