[Qgis-developer] raster visualization
Agustin Lobo alobolistas at gmail.com
Sun Apr 22 13:35:29 EDT 2012
This procedure would not work well for thematic maps (qualitative variable) but
I think it is reasonable as initial default. Nevertheles, a
qualitative scheme should be
ready for thematic maps (i.e. landcover, vegetation or soil maps). Maybe the
12 classes color table from colorbrewer could be a good first option:
http://colorbrewer2.org/index.php?type=qualitative&scheme=Set3&n=12
Also, median should be used instead of mean and mad instead of sd to calculate
the clipping (at least optionally) as raster layers do have outliers:
mad is just
the median of the absolute value of the differences to the median:
median(abs(x-median(x))
Agus
El día 20 de abril de 2012 14:46, Tim Sutton <lists at linfiniti.com> escribió:
> Hi
> On Fri, Apr 20, 2012 at 2:17 PM, Marco Hugentobler
> <marco.hugentobler at sourcepole.ch> wrote:
>> Hi
>>>BTW Freak out will go after resampler branch is merged....
>> I've managed to convert freakout style to singleband pseudocolor in the
>> project file / qml conversion to the new format :-)
>>> - visualizing monoband rasters could be improved:
>>> - why not loading it with a greyscale by default? or with a colour ramp?
>>> - why not adding a dtm colour table (we can take the one
>> I'd like to improve selecting colorramps in the raster resampler branch
>> (that would even allow us to add a freakout color ramp for trips down memory
>> lane).
>> Default style: I'm not sure what would be a good default, since we don't
>> know the value range at the beginning (at least not without doing a time
>> consuming value scan). Do you have any ideas (maybe a partial raster scan to
>> speed things up?).
> Yes - Julien had a really nice suggestion to implement the following logic:
> - on initial load of a raster, generate a quicklook that is the larger
> of 1/4 screen resolution or 500x500 pixels by sampling every nth pixel
> - generate a histogram from the quicklook
> - calculate clipped 2% - 96% range min max for each band
> - apply a histogram stretch based on the above
> - the histogram could be used for generating the graph in raster
> props, and the quicklook could be used to create thumbs and previews
> etc
> - ideally we should cache these quicklooks and only regenerate them if
> the underlying dataset has changed
> I believe if we do this we will have fast initial load and the images
> (grayscale and rgb) will 'look right' when first loaded (i.e with good
> contrast) and it would not be necessary to assign any color value to
> grayscales by default.
> Regards
> Tim
>> Regards,
>> Marco
>> On 20.04.2012 11:10, Tim Sutton wrote:
>>> Hi
>>> On Fri, Apr 20, 2012 at 10:47 AM, Giovanni Manghi
>>> <giovanni.manghi at gmail.com>  wrote:
>>>> On Fri, 2012-04-20 at 10:19 +0200, Paolo Cavallini wrote:
>>>>> Hi all.
>>>>> Visualizing monoband rasters could be improved:
>>>>> in/usr/lib/grass64/etc/colors/terrain), possibly replacing the Freak out
>>>>> one?
>>>> +100
>>>> much needed improvements
>>> All good ideas but we are feature frozen so lets first focus on
>>> releasing 1.8 and then we can do these.
>>> Regards
>>> Tim
>>>> -- Giovanni --
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Dr. Marco Hugentobler
>> Sourcepole -  Linux&  Open Source Solutions
>> Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
>> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>> Technical Advisor QGIS Project Steering Committee
> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
>  * QGIS programming and support services
>  * Mapserver and PostGIS based hosting plans
>  * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
