[Qgis-developer] raster visualization
Andrea Peri
aperi2007 at gmail.com
Fri Apr 20 09:10:43 EDT 2012
>- on initial load of a raster, generate a quicklook that is the larger
>of 1/4 screen resolution or 500x500 pixels by sampling every nth pixel
>- generate a histogram from the quicklook
>- calculate clipped 2% - 96% range min max for each band
>- apply a histogram stretch based on the above
>- the histogram could be used for generating the graph in raster
>props, and the quicklook could be used to create thumbs and previews
>etc
>- ideally we should cache these quicklooks and only regenerate them if
>the underlying dataset has changed
>I believe if we do this we will have fast initial load and the images
>(grayscale and rgb) will 'look right' when first loaded (i.e with good
>contrast) and it would not be necessary to assign any color value to
>grayscales by default.
>Regards
just my 2 ct.
I guess the more important capability with raster is to open they faster
possible.
I fear calculate all these values on first opened take more time than what
is waitable for the open of a raster.
Perhaps this action should be choosable by settings ?
Of course I see our situation.
Our situation is of more sets of raster (7-800 each set) where every raster
is grey level or true color of 3-400 Mbyte each.
And all these raster are accessible by a remote shared server to our users.
For a total, actually, of about 13.000 rasters.
I don't understand if this new feature could be really usable in a
situation like our.
Andrea Peri
qwerty àèìòù
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120420/351f8c18/attachment.html
