[Qgis-developer] plugin zoom question
SJWC GIS
sjwcgis at gmail.com
Wed Apr 25 12:28:46 EDT 2012
Hi Bernhard,
I tried again this morning (using the Python Console, which I didn't
actually realize existed before your email) and sure enough, it worked.
I'm still having the problem, but I think I've been able to narrow it down
a little better. The method actually works when I'm using a push button to
trigger it. However, I'm also using a QCompleter to provide autocomplete
functionality with a list of addresses. When the QCompleter is activated
(a value is selected) the program crashes. This seems odd to me, since I
can tell from the output that the whole method executes -- it crashes some
time after I refresh the map canvas. I don't think the map canvas refresh
in itself crashes it (logging seems to indicate that that method finishes)
but rather something related to my QCompleter's activate signal. Any ideas
on why this might be the case?
In any case, thanks for your help...it got me a bit further down the stream.
Aaron
On Tue, Apr 24, 2012 at 11:43 PM, <bernhard.stroebl at jena.de> wrote:
> Hi Aaron,
> the code works for me when entering it in the console directly (QGIS
> 1.7.1/WinXP)
> Maybe there is something wrong with your coordinates? Try to enter values
> for x and y directly in the code and see if it works.
> Bernhard
> Am 25.04.2012 07:00, schrieb Denis Rouzaud:
> Hi,
>> How is defined self.plugin ?
>> On 04/25/2012 01:30 AM, SJWC GIS wrote:
>>> Hello all,
>>> I've written a piece of code that will search a database for a given
>>> point, and then return that point so we can center the map canvas on
>>> it and zoom in. Unfortunately, it's not working. QGIS crashes after
>>> the code executes, leaving no error messages behind. Is there a better
>>> way to center/zoom to a given point? I've tried the canvas method
>>> "centerWithZoom" as well, with no success. (It also crashes.) I have
>>> checked my coords -- they are in the proper projection (the same as
>>> the mapCanvas) and I haven't reversed them. Any other ideas/methods of
>>> accomplishing this are greatly appreciated. Thanks!
>>> Aaron
>>> x = result[0][1]
>>> y = result[0][2]
>>> xscale = 1.0
>>> # Get the map canvas
>>> mc = self.plugin.iface.mapCanvas()
>>> height2 = mc.extent().height() * xscale / 2.0
>>> width2 = mc.extent().width() * xscale / 2.0
>>> rect = QgsRectangle(x-width2,y-**height2,x+width2,y+height2)
>>> # Set the extent to our new rectangle
>>> mc.setExtent(rect)
>>> # Refresh the map
>>> mc.refresh()
> ________ Information from NOD32 ________
> This message was checked by NOD32 Antivirus System for Linux Mail Server.
> http://www.nod32.com
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120425/f894a2d3/attachment.html
