[Qgis-developer] Documentation and internationalization: also slides?
Yves Jacolin yjacolin at free.fr
Thu Apr 26 08:26:36 EDT 2012
Le jeudi 26 avril 2012 13:52:20 Paolo Cavallini a écrit :
> Hi all.
> I think it would be good to add some slide show to the documentation
> material. However, I do not see an easy way of incorporating rst2s5 into
> the translation workflow: does anybody know how (if) possible?
> Thanks.
Hello Paolo,
I am using rst2s5 for all my training materials but there are some issue:
* you should use header of level 2 for each slide. Level 1 is for the main
title. Level 3 and other are shown in the same slide.
* Some directive are not working correctly (ie :ref: for instance).
*  I create link to s5 html page from an index file (rst convert into html). S5
html pages are created from the MakeFile this way:
$(RST2S5BUILD) --theme-url ui/c2c slides/1_presentation.rst
$(BUILDDIR)/s5/cours/presentation_slides.html
So you can just add s5 target into the Makefile to create s5 html page from a
specific directory (aka nammed "slides" for instance) where you can put some
files (one slideshow by file).
Am I clear?
Y.
Yves Jacolin
http://yjacolin.gloobe.org
