[Qgis-developer] Documentation and internationalization: also
slides?
Paolo Cavallini
cavallini at faunalia.it
Thu Apr 26 10:39:23 EDT 2012
Il 26/04/2012 14:26, Yves Jacolin ha scritto:
> I am using rst2s5 for all my training materials but there are some issue:
> * you should use header of level 2 for each slide. Level 1 is for the main
> title. Level 3 and other are shown in the same slide.
yes, I'm aware of this, it should not be a problem
> Am I clear?
> Y.
Yes, the problem (as noted by PC2) is that it is relatively difficult to
integrate them in the translation process, so we can probably wait
integrating this material until s5 will be supported by sphinx. BTW,
does anybody know if there are plans for this to happen soon?
All the best.
Paolo Cavallini
See: http://www.faunalia.it/pc
