[Qgis-developer] Adding GRASS modules
Paolo Cavallini
cavallini at faunalia.it
Thu Apr 26 11:12:51 EDT 2012
Hi all.
Now that sextante is in full swing, I think reaching feature parity with
the current grass plugin modules (GPM) is a priority.
This is a very easy task:
* check if a GPM is present in sextante
- if yes, check if parameters match those in GPM
. if yes, ok
. if not, change the description file, e.g. [0] in order to
replicate the behaviour of GPM
- if not, you can add it to the list of missing modules, or add it
yourself.
This will greatly improve the usability, and will make the user
migration easier.
I'm ready to help volunteers, and I'm sure Victor will be happy too.
All the best.
[0]sextante/soft/bindings/qgis-plugin/src/sextante/grass/description/r.buffer.txt
r.buffer
r.buffer
Raster (r.*)
ParameterRaster|input|input|False
ParameterString|distances|distances|100,200,300
ParameterSelection|units|units|meters;kilometers;feet;miles;nautmiles
ParameterBoolean|-z|-z|True
ParameterBoolean|-q|-q|True
OutputRaster|output|output
To add a parameter as Advanced (GPM: advanced=yes), just add a "*"
before the parameter (*ParameterXXX) and it becomes advanced.
Paolo Cavallini
See: http://www.faunalia.it/pc
