[Qgis-developer] Re: Config fails on find of spatialindex library
Larry Shaffer larrys at dakotacarto.com
Sun Apr 29 18:46:09 EDT 2012
On Sun, Apr 29, 2012 at 3:50 PM, Larry Shaffer <larrys at dakotacarto.com>wrote:
> Hi,
> Tried building master branch today, on Mac 10.7.3, but build fails when
> searching for spatialindex library.
> -- Found GSL: /Library/Frameworks/GSL.framework
> -- Found FCGI: /usr/local/lib/libfcgi.dylib
> CMake Error: The following variables are used in this project, but they
> are set to NOTFOUND.
> Please set them or make sure they are set and tested correctly in the
> CMake files:
> SPATIALINDEX_LIBRARY
>     linked by target "qgis_core" in directory
> /Users/larrys/QGIS/github-nightly/quantum-gis/src/core
> I did some searching and found this change by JEF 5 days ago [0]. Also,
> there appears to be no 'spatialindex' directory in src/core anymore in the
> master branch.
> Is spatialindex library now a system environment build requirement,
> instead of internal? If so, where can I get the appropriate library?
> There's a header file here (Kyngchaos.com GEOS framework):
> /Library/Frameworks/GEOS.framework/Versions/3/Headers/spatialIndex.h
> but, it doesn't look like what I should be including.
> [0]
> https://github.com/qgis/Quantum-GIS/commit/c10b040ec751c503594776fece9ee96961dec678
I see [1][2] is where internal spatialindex support was removed along with
spatialite (which was then readded, later). I tracked down the library [3]
and installed (successfully) versions 1.7.1 back to 1.4.0, but QGIS build
always fails at same point [4] regardless of library version installed.
[1] http://hub.qgis.org/issues/4805
[2]
https://github.com/qgis/Quantum-GIS/commit/c56491b11124f9ceefa9b6b3d501374755aac84c#src/core
[3] http://libspatialindex.github.com/
[4] http://dl.dropbox.com/u/4058089/qgis/spatialindex_build-failure.pdf
Regards,
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120429/352462ee/attachment.html
