[Qgis-developer] Building QGIS in Mac OS X (Mountain Lion i.e. 10.8) with QtSQL support
Noli Sicad
nsicad at gmail.com
Fri Aug 3 16:02:54 PDT 2012
How can I incorporate qmake in my system?
It seems that I can't use qmake in my terminal right now.
See this logs.
Last login: Sat Aug 4 08:56:51 on ttys004
Nolis-MacBook-Pro:bin nsicad$ qmake --help
-bash: qmake: command not found
Nolis-MacBook-Pro:bin nsicad$ ls
Designer.app moc qt3to4
Linguist.app pixeltool.app qttracereplay.app
QMLViewer.app qcollectiongenerator rcc
lconvert qdoc3 uic
lrelease qhelpconverter.app uic3
lupdate qhelpgenerator xmlpatterns
macdeployqt qmake xmlpatternsvalidator
Nolis-MacBook-Pro:bin nsicad$ qmake -help
Double clicking qmake works.
Noli
On 8/4/12, Noli Sicad <nsicad at gmail.com> wrote:
> It is stlll not clear to me what to do with QtSDK (i.e. Qt 4.7.4) and
> XCode 4.x with Command Line Tool for compiling QGIS in Mac OS X.
> Tim has this wiki - Building QGIS 0.8 with Qt4.x for Ubuntu.
> https://help.ubuntu.com/community/BuildingQuantumGisPoint8FromSource
> Can some lighten me how to use QtSDK 4.7.4 for Building QGIS in Mac OS X?
> Noli
> On 8/3/12, William Kyngesburye <woklist at kyngchaos.com> wrote:
>> As it says, "when using a system SDK". If you just compile for your
>> current
>> system, with no SDK options, you don't need to do this.
>> I suppose this should be removed, since I was aiming for simple current
>> system builds in the instructions.
>> On Aug 2, 2012, at 11:44 PM, Noli Sicad wrote:
>>> My QtSDK for Mac OS X is installed in:
>>> /Users/nsicad/QtSDK/Desktop/Qt/474/gcc/
>>> See screenshot attached.
>>> What i am going to do inorder that qt library, include, etc can be
>>> founded during compilation?
>>> This is copied (below) from Building QGIS for Mac OS ...
>>> Leopard note: Qt includes a couple non-framework libraries in /usr/lib.
>>> When using a system SDK these libraries will not be found. To fix this
>>> problem,
>>> add symlinks to /usr/local:
>>> sudo ln -s /usr/lib/libQtUiTools.a /usr/local/lib/
>>> sudo ln -s /usr/lib/libQtCLucene.dylib /usr/local/lib/
>>> These should then be found automatically. Earlier systems
>>> may need some help by adding '-L/usr/local/lib' to
>>> CMAKE_SHARED_LINKER_FLAGS,
>>> CMAKE_MODULE_LINKER_FLAGS and CMAKE_EXE_LINKER_FLAGS in the cmake build.
>>> From the above statements what I am going to do with my QtSDK
>>> installation? What need to copy to /usr/lib or link?
>>> Thanks.
>>> Noli
>>> <Screen Shot 2012-08-03 at 2.23.31 PM.png>
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> "Mon Dieu! but they are all alike. Cheating, murdering, lying, fighting,
>> and all for things that the beasts of the jungle would not deign to
>> possess
>> - money to purchase the effeminate pleasures of weaklings. And yet
>> withal
>> bound down by silly customs that make them slaves to their unhappy lot
>> while
>> firm in the belief that they be the lords of creation enjoying the only
>> real
>> pleasures of existence....
>> - the wisdom of Tarzan
