[Qgis-developer] Building QGIS in Mac OS X (Mountain Lion i.e. 10.8) with QtSQL support
Noli Sicad
nsicad at gmail.com
Fri Aug 3 17:55:57 PDT 2012
It seems that compiling in Linux (i.e. Ubuntu) as outlined by Tim
(below) is much easier to understand than the instruction in Mac OS X.
https://help.ubuntu.com/community/BuildingQuantumGisPoint8FromSource
Is the instruction above using qmake instead of cmake?
Would it possible we can iron out this document i.e. building QGIS in
Mac OS X to make it easier for use to understand and compile QGIS in
Mac OS X?
Thanks.
Noli
On 8/4/12, Noli Sicad <nsicad at gmail.com> wrote:
> Do we still need cmake for building QGIS Mac OS X when using QtSDK (i.e.
> qmake)?
> This instruction below.
> Copied from Building QGIS for Mac OSX (below)
> 5.3. Install CMake for OSX
> Get the latest source release from here:
> http://www.cmake.org/cmake/resources/software.html
> Binary installers are available for OS X, but they are not recommended
> (2.4 versions install in /usr instead of /usr/local, and 2.6+ versions are
> a
> strange application). Instead, download the source.
> NOTE: 2.8.5 is broken for detecting part of Qt. Fixed in 2.8.6.
> Double-click the source tarball, then cd to the source folder and:
> ./bootstrap --docdir=/share/doc/CMake --mandir=/share/man
> make
> sudo make install
> Noli
> On 8/4/12, Larry Shaffer <larrys at dakotacarto.com> wrote:
>> Noli,
>> On Fri, Aug 3, 2012 at 5:02 PM, Noli Sicad <nsicad at gmail.com> wrote:
>>> How can I incorporate qmake in my system?
>>> It seems that I can't use qmake in my terminal right now.
>> This is because the place where qmake is installed with the SDK is not
>> in your PATH environment variable.
>> You will need to edit ~/.bash_profile (create if not there yet) and
>> add the path to the 'bin' you noted to the PATH variable:
>> export PATH=/path/to/sdk/bin:$PATH
>> Then, log in to a new Terminal session (e.g. restart Terminal). qmake
>> will be found and can be used in compiling.
>> Read 'man bash' for more details on its config files.
>> I will be available on #qgis channel on irc.freenode.net most of the
>> day today, if you want more help (nickname of 'dakcarto').
>> Larry
>>> See this logs.
>>> Last login: Sat Aug 4 08:56:51 on ttys004
>>> Nolis-MacBook-Pro:bin nsicad$ qmake --help
>>> -bash: qmake: command not found
>>> Nolis-MacBook-Pro:bin nsicad$ ls
>>> Designer.app moc qt3to4
>>> Linguist.app pixeltool.app qttracereplay.app
>>> QMLViewer.app qcollectiongenerator rcc
>>> lconvert qdoc3 uic
>>> lrelease qhelpconverter.app uic3
>>> lupdate qhelpgenerator xmlpatterns
>>> macdeployqt qmake xmlpatternsvalidator
>>> Nolis-MacBook-Pro:bin nsicad$ qmake -help
>>> Double clicking qmake works.
>>> Noli
>>>> It is stlll not clear to me what to do with QtSDK (i.e. Qt 4.7.4) and
>>>> XCode 4.x with Command Line Tool for compiling QGIS in Mac OS X.
>>>> Tim has this wiki - Building QGIS 0.8 with Qt4.x for Ubuntu.
>>>> Can some lighten me how to use QtSDK 4.7.4 for Building QGIS in Mac OS
>>>> X?
>>>> Noli
>>>> On 8/3/12, William Kyngesburye <woklist at kyngchaos.com> wrote:
>>>>> As it says, "when using a system SDK". If you just compile for your
>>>>> current
>>>>> system, with no SDK options, you don't need to do this.
>>>>> I suppose this should be removed, since I was aiming for simple
>>>>> current
>>>>> system builds in the instructions.
>>>>> On Aug 2, 2012, at 11:44 PM, Noli Sicad wrote:
>>>>>> My QtSDK for Mac OS X is installed in:
>>>>>> /Users/nsicad/QtSDK/Desktop/Qt/474/gcc/
>>>>>> See screenshot attached.
>>>>>> What i am going to do inorder that qt library, include, etc can be
>>>>>> founded during compilation?
>>>>>> This is copied (below) from Building QGIS for Mac OS ...
>>>>>> Leopard note: Qt includes a couple non-framework libraries in
>>>>>> /usr/lib.
>>>>>> When using a system SDK these libraries will not be found. To fix
>>>>>> this
>>>>>> problem,
>>>>>> add symlinks to /usr/local:
>>>>>> sudo ln -s /usr/lib/libQtUiTools.a /usr/local/lib/
>>>>>> sudo ln -s /usr/lib/libQtCLucene.dylib /usr/local/lib/
>>>>>> These should then be found automatically. Earlier systems
>>>>>> may need some help by adding '-L/usr/local/lib' to
>>>>>> CMAKE_SHARED_LINKER_FLAGS,
>>>>>> CMAKE_MODULE_LINKER_FLAGS and CMAKE_EXE_LINKER_FLAGS in the cmake
>>>>>> build.
>>>>>> From the above statements what I am going to do with my QtSDK
>>>>>> installation? What need to copy to /usr/lib or link?
>>>>>> Thanks.
>>>>>> Noli
>>>>>> <Screen Shot 2012-08-03 at 2.23.31 PM.png>
>>>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>>>> http://www.kyngchaos.com/
>>>>> "Mon Dieu! but they are all alike. Cheating, murdering, lying,
>>>>> fighting,
>>>>> and all for things that the beasts of the jungle would not deign to
>>>>> possess
>>>>> - money to purchase the effeminate pleasures of weaklings. And yet
>>>>> withal
>>>>> bound down by silly customs that make them slaves to their unhappy lot
>>>>> while
>>>>> firm in the belief that they be the lords of creation enjoying the
>>>>> only
>>>>> real
>>>>> pleasures of existence....
>>>>> - the wisdom of Tarzan
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
