[Qgis-developer] Building QGIS in Mac OS X (Mountain Lion i.e. 10.8) with QtSQL support
Larry Shaffer larrys at dakotacarto.com
Fri Aug 3 18:02:32 PDT 2012
Noli,
On Fri, Aug 3, 2012 at 6:30 PM, Noli Sicad <nsicad at gmail.com> wrote:
> Do we still need cmake for building QGIS Mac OS X when using QtSDK (i.e. qmake)?
> This instruction below.
Yes CMake is necessary. qmake is used to query where Qt components are
installed. See results of:
qmake -query
CMake is the system used to aid in the cross-platform compiling of the
C++ code QGIS is written in and uses the information provided by qmake
during its configure process. qmake is not used for this purpose, like
when compiling other Qt programs. Though, I'm not sure if qmake is
used for anything else in the compiling process.
If it doesn't say 'optional' in the INSTALL notes, it's not. INSTALL
is up-to-date and accurate, excepting anything that might pop up
during Mt. Lion testing. Also, INSTALL is the most up-to-date
document, with other sources possibly helpful with problems
encountered, i.e. use INSTALL as your guide.
One thing that might be good to add to the Mac OS X INSTALL notes is
optional install of ccache, currently only noted for Linux installs:
3.4. Setup ccache (Optional). It installs and works fine on Mac.
Since it takes some time to compile QGIS, ccache offers a significant
speedup on subsequent compiling, especially if you do not switch git
branches. However, I recommend you get QGIS compiled first before
adding optional ccache support.
Larry
> Copied from Building QGIS for Mac OSX (below)
>   5.3. Install CMake for OSX
> Get the latest source release from here:
> http://www.cmake.org/cmake/resources/software.html
> Binary installers are available for OS X, but they are not recommended
> (2.4 versions install in /usr instead of /usr/local, and 2.6+ versions are a
> strange application). Instead, download the source.
> NOTE: 2.8.5 is broken for detecting part of Qt. Fixed in 2.8.6.
> Double-click the source tarball, then cd to the source folder and:
>   ./bootstrap --docdir=/share/doc/CMake --mandir=/share/man
>   make
>   sudo make install
> Noli
> On 8/4/12, Larry Shaffer <larrys at dakotacarto.com> wrote:
>> Noli,
>> On Fri, Aug 3, 2012 at 5:02 PM, Noli Sicad <nsicad at gmail.com> wrote:
>>> How can I incorporate qmake in my system?
>>> It seems that I can't use qmake in my terminal right now.
>> This is because the place where qmake is installed with the SDK is not
>> in your PATH environment variable.
>> You will need to edit ~/.bash_profile (create if not there yet) and
>> add the path to the 'bin' you noted to the PATH variable:
>> export PATH=/path/to/sdk/bin:$PATH
>> Then, log in to a new Terminal session (e.g. restart Terminal). qmake
>> will be found and can be used in compiling.
>> Read 'man bash' for more details on its config files.
>> I will be available on #qgis channel on irc.freenode.net most of the
>> day today, if you want more help (nickname of 'dakcarto').
>> Larry
>>> See this logs.
>>> Last login: Sat Aug  4 08:56:51 on ttys004
>>> Nolis-MacBook-Pro:bin nsicad$ qmake --help
>>> -bash: qmake: command not found
>>> Nolis-MacBook-Pro:bin nsicad$ ls
>>> Designer.app            moc                     qt3to4
>>> Linguist.app            pixeltool.app           qttracereplay.app
>>> QMLViewer.app           qcollectiongenerator    rcc
>>> lconvert                qdoc3                   uic
>>> lrelease                qhelpconverter.app      uic3
>>> lupdate                 qhelpgenerator          xmlpatterns
>>> macdeployqt             qmake                   xmlpatternsvalidator
>>> Nolis-MacBook-Pro:bin nsicad$ qmake -help
>>> Double clicking qmake works.
>>> Noli
>>> On 8/4/12, Noli Sicad <nsicad at gmail.com> wrote:
>>>> It is stlll not clear to me what to do with QtSDK (i.e. Qt 4.7.4) and
>>>> XCode 4.x with Command Line Tool for compiling QGIS in Mac OS X.
>>>> Tim has this wiki - Building QGIS 0.8 with Qt4.x for Ubuntu.
>>>> https://help.ubuntu.com/community/BuildingQuantumGisPoint8FromSource
>>>> Can some lighten me how to use QtSDK 4.7.4 for Building QGIS in Mac OS
>>>> X?
>>>> Noli
>>>> On 8/3/12, William Kyngesburye <woklist at kyngchaos.com> wrote:
>>>>> As it says, "when using a system SDK".  If you just compile for your
>>>>> current
>>>>> system, with no SDK options, you don't need to do this.
>>>>> I suppose this should be removed, since I was aiming for simple current
>>>>> system builds in the instructions.
>>>>> On Aug 2, 2012, at 11:44 PM, Noli Sicad wrote:
>>>>>> My QtSDK for Mac OS X is installed in:
>>>>>> /Users/nsicad/QtSDK/Desktop/Qt/474/gcc/
>>>>>> See screenshot attached.
>>>>>> What i am going to do inorder that qt library, include, etc  can be
>>>>>> founded during compilation?
>>>>>> This is copied (below) from Building QGIS for Mac OS ...
>>>>>> Leopard note: Qt includes a couple non-framework libraries in
>>>>>> /usr/lib.
>>>>>> When using a system SDK these libraries will not be found. To fix this
>>>>>> problem,
>>>>>> add symlinks to /usr/local:
>>>>>>  sudo ln -s /usr/lib/libQtUiTools.a /usr/local/lib/
>>>>>>  sudo ln -s /usr/lib/libQtCLucene.dylib /usr/local/lib/
>>>>>> These should then be found automatically. Earlier systems
>>>>>> may need some help by adding '-L/usr/local/lib' to
>>>>>> CMAKE_SHARED_LINKER_FLAGS,
>>>>>> CMAKE_MODULE_LINKER_FLAGS and CMAKE_EXE_LINKER_FLAGS in the cmake
>>>>>> build.
>>>>>> From the above statements what I am going to do with my QtSDK
>>>>>> installation? What need to copy to /usr/lib or link?
>>>>>> Thanks.
>>>>>> Noli
>>>>>> <Screen Shot 2012-08-03 at 2.23.31 PM.png>
>>>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>>>> http://www.kyngchaos.com/
>>>>> "Mon Dieu! but they are all alike.  Cheating, murdering, lying,
>>>>> fighting,
>>>>> and all for things that the beasts of the jungle would not deign to
>>>>> possess
>>>>> - money to purchase the effeminate pleasures of weaklings.  And yet
>>>>> withal
>>>>> bound down by silly customs that make them slaves to their unhappy lot
>>>>> while
>>>>> firm in the belief that they be the lords of creation enjoying the only
>>>>> real
>>>>> pleasures of existence....
>>>>> - the wisdom of Tarzan
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
