[Qgis-developer] Building QGIS in Mac OS X (Mountain Lion i.e. 10.8) with QtSQL support
Noli Sicad
nsicad at gmail.com
Fri Aug 3 21:24:03 PDT 2012
Any suggestion of the better SIP and PyQt version that works with QGIS?
Which SIP and PyQt version that works with QGIS?
Noli
On 8/4/12, William Kyngesburye <woklist at kyngchaos.com> wrote:
> That's a problem to ask on the PyQt list.
> On Aug 3, 2012, at 10:45 PM, Noli Sicad wrote:
>> Cmake no problem now.
>> Nolis-MacBook-Pro:~ nsicad$ which cmake
>> /usr/local/bin/cmake
>> Now, I got problem compiling SIP.
>> Last login: Sat Aug 4 13:35:51 on ttys005
>> Nolis-MacBook-Pro:sip-4.13.4-snapshot-5775580258b3 nsicad$ python2.7
>> configure.py -d /Library/Python/2.7/site-packages -b /usr/local/bin -e
>> /usr/local/include -v /usr/local/share/sip
>> This is SIP 4.13.4-snapshot-5775580258b3 for Python 2.7.2 on darwin.
>> The SIP code generator will be installed in /usr/local/bin.
>> The sip module will be installed in /Library/Python/2.7/site-packages.
>> The sip.h header file will be installed in /usr/local/include.
>> The default directory to install .sip files in is /usr/local/share/sip.
>> The platform/compiler configuration is macx-g++.
>> Creating siplib/sip.h...
>> Creating siplib/siplib.c...
>> Creating siplib/siplib.sbf...
>> Creating sipconfig.py...
>> Creating top level Makefile...
>> Creating sip code generator Makefile...
>> Creating sip module Makefile...
>> Nolis-MacBook-Pro:sip-4.13.4-snapshot-5775580258b3 nsicad$ make
>> make[1]: Nothing to be done for `all'.
>> cc -c -pipe -fPIC -Os -w -DNDEBUG -I.
>> -I/System/Library/Frameworks/Python.framework/Versions/2.7/include/python2.7
>> -o siplib.o siplib.c
>> -o apiversions.o apiversions.c
>> -o descriptors.o descriptors.c
>> -o qtlib.o qtlib.c
>> -o threads.o threads.c
>> -o objmap.o objmap.c
>> -o voidptr.o voidptr.c
>> c++ -c -pipe -fPIC -Os -w -DNDEBUG -I.
>> -o bool.o bool.cpp
>> make[1]: c++: No such file or directory
>> make[1]: *** [bool.o] Error 1
>> make: *** [all] Error 2
>> Noli
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Those people who most want to rule people are, ipso-facto, those least
> suited to do it."
> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
