[Qgis-developer] Building QGIS in Mac OS X (Mountain Lion i.e. 10.8) with QtSQL support
William Kyngesburye
woklist at kyngchaos.com
Fri Aug 3 21:19:23 PDT 2012
That's a problem to ask on the PyQt list.
On Aug 3, 2012, at 10:45 PM, Noli Sicad wrote:
> Cmake no problem now.
> Nolis-MacBook-Pro:~ nsicad$ which cmake
> /usr/local/bin/cmake
> Now, I got problem compiling SIP.
> Last login: Sat Aug 4 13:35:51 on ttys005
> Nolis-MacBook-Pro:sip-4.13.4-snapshot-5775580258b3 nsicad$ python2.7
> configure.py -d /Library/Python/2.7/site-packages -b /usr/local/bin -e
> /usr/local/include -v /usr/local/share/sip
> This is SIP 4.13.4-snapshot-5775580258b3 for Python 2.7.2 on darwin.
> The SIP code generator will be installed in /usr/local/bin.
> The sip module will be installed in /Library/Python/2.7/site-packages.
> The sip.h header file will be installed in /usr/local/include.
> The default directory to install .sip files in is /usr/local/share/sip.
> The platform/compiler configuration is macx-g++.
> Creating siplib/sip.h...
> Creating siplib/siplib.c...
> Creating siplib/siplib.sbf...
> Creating sipconfig.py...
> Creating top level Makefile...
> Creating sip code generator Makefile...
> Creating sip module Makefile...
> Nolis-MacBook-Pro:sip-4.13.4-snapshot-5775580258b3 nsicad$ make
> make[1]: Nothing to be done for `all'.
> cc -c -pipe -fPIC -Os -w -DNDEBUG -I.
> -I/System/Library/Frameworks/Python.framework/Versions/2.7/include/python2.7
> -o siplib.o siplib.c
> -o apiversions.o apiversions.c
> -o descriptors.o descriptors.c
> -o qtlib.o qtlib.c
> -o threads.o threads.c
> -o objmap.o objmap.c
> -o voidptr.o voidptr.c
> c++ -c -pipe -fPIC -Os -w -DNDEBUG -I.
> -o bool.o bool.cpp
> make[1]: c++: No such file or directory
> make[1]: *** [bool.o] Error 1
> make: *** [all] Error 2
> Noli
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Those people who most want to rule people are, ipso-facto, those least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
