[Qgis-developer] Map canvas flickers
Matthias Kuhn matthias.kuhn at gmx.ch
Sat Aug 4 03:13:05 PDT 2012
Hi Ivan,
As far as I can see, it is very likely that these issues are related.
If you want to be sure and you are able to compile qgis by yourself, you
can check the patch I attached in the other thread.
Regards
On Fri, 2012-08-03 at 22:05 +0200, Ivan Mincik wrote:
> Hi Matthias,
> do you think that this problem is the same as discussed it this [1]
> thread ?
> Thanks for interest to this issue.
> 1 -
> http://lists.osgeo.org/pipermail/qgis-developer/2012-August/021472.html
