[Qgis-developer] Building QGIS in Mac OS X (Mountain Lion i.e. 10.8) with QtSQL support
John Abraham jea at hbaspecto.com
Sat Aug 4 05:41:22 PDT 2012
I hope this isn't counter productive, but I've found the macports system to be a useful way of understanding the steps to compile on OSX. Essentially, a portfile in macports has the instructions for downloading the unix source code, has a set of patch files to the unix source/makefiles, and lists the other packages that are required as dependencies. It does take a little while to understand the macports system, but when it works compiling from source is as simple as "sudo port install qgis".
I havent tried macports' qgis on mountain lion, so there may be issues. But if there are issues you could fix them in the portfile and contribute the fixes to the rest of us that way.
John Abraham
Sent from my iPhone, please excuse any typos.
On 2012-08-03, at 6:55 PM, qgis-developer-request at lists.osgeo.org wrote:
> Message: 5
> Date: Sat, 4 Aug 2012 10:55:57 +1000
> From: Noli Sicad <nsicad at gmail.com>
> To: Larry Shaffer <larrys at dakotacarto.com>
> Cc: qgis-developer <qgis-developer at lists.osgeo.org>,    William
>    Kyngesburye <kyngchaos at kyngchaos.com>
> Subject: Re: [Qgis-developer] Building QGIS in Mac OS X (Mountain Lion
> Message-ID:
>    <CADs9uc8ddRt2juyiCjDqKfvn54tGKsgXam2Ck9viVjKx_8WeiA at mail.gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1
> It seems that compiling in Linux (i.e. Ubuntu) as outlined by Tim
> (below) is much easier to understand than the instruction in Mac OS X.
> https://help.ubuntu.com/community/BuildingQuantumGisPoint8FromSource
> Is the instruction above using qmake instead of cmake?
> Would it possible we can iron out this document i.e. building QGIS in
> Mac OS X to make it easier for use to understand and compile QGIS in
> Mac OS X?
> Thanks.
> Noli
