[Qgis-developer] Building QGIS in Mac OS X (Mountain Lion i.e. 10.8) with QtSQL support
John C. Tull
jctull at gmail.com
Sun Aug 5 09:03:40 PDT 2012
On Aug 4, 2012, at 8:11 PM, Larry Shaffer <larrys at dakotacarto.com> wrote:
> Note: Xcode.app now contains all dev directory structure, and you can
> use xcrun to work with it, but I preferred to install the command line
> tools. You will probably want to uninstall any previous XCode version
> first. I used the .dmg installers downloaded from my Apple developer
> account, instead of Mac App Store. Not sure if the command line tools
> (115 MB dl) can be installed, and work, without installing Xcode.app
> (1.8 GB dl), since I installed Xcode.app first.
You can install the command line tools from the app store version of Xcode. Open Xcode, then open Preferences and click on the 'Downloads' section at the top. You will see Command Line Tools as an install option from there.
Regards,
John
