[Qgis-developer] Moving SEXTANTE into QGIS core
Tim Sutton
lists at linfiniti.com
Mon Aug 6 02:07:31 PDT 2012
Hi
On Mon, Aug 6, 2012 at 9:18 AM, Victor Olaya <volayaf at gmail.com> wrote:
>>> Just 1 question: I started working with a git clone right away,
>>> thinking the svn repo would be abandoned, but Victor tells me he is
>>> still commiting to svn. Could this be a problem in a future merge?
>> Not I should be able to pull these changes through until svn is frozen.
> The reason why I want to do this is because I have no experience with
> GIT and I have now some ideas and more time that what I will have
> after the end of the month, so I prefer to concentrate on developing
> and not in learning how to properly use GIT, since I guess it is a bit
> different and misusing it can cause trouble later.
> If Camilo works on his own copy, how I can see his changes and work
> with them if I use just the SVN repo ? I guess I have a more SVN-like
> approach to version control after all these years (and some experience
> with messy commiters that made use waste time...), so I see it a bit
> more complicated.
> If it is not a problem, I would prefer to keep on working on the SVN
> and then freeze the SVN on the 20th as I mentioned, apply a big patch
> to the GIT repo and from that moment work only on GIT.
> Of course, comments are welcome, since maybe there is an easy way of
> doing this in GIT (maybe Camilo can keep on working in his GIT repo
> and commit changes to the SVN as well...)
Yes you can continue working in svn until you decide to freeze it,
then I will sync your changes across one way or another.
Camilo it might be better for you to do the same until Victor is ready
to make the switch. If you really want to work with git, you will need
to take my git-svn repo and copy it locally so that the uuids match.
Let me know and I will tar it up for you.
Regards
Tim
> Regards
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
